Hi
Is there anyone had experience with these cheap Russian made 2.2 uF 400 V PIO Capacitors. (About $2 each on eBay)
http://cgi.ebay.ca/2-2-uF-400-V-PIO...03968556QQihZ008QQcategoryZ4662QQcmdZViewItem
I’m just wondering how good they are in sound quality? (For example when using for signal coupling on linestage amplifier). Jensen makes good PIO capacitors too but they are expensive.
Thanks.
Thanks.
take care these are not PIOs but polyethylene caps !!!
I own K40Y9 ones they are true PIO caps and sound very very good ! but doesn't exist in 2.2uf ...
Actually, that might not be such a bad thing. A quick search reveals polyethelene's dielectric constant slots between polypropylene and polystyrene. If like the K40y-9 the leads are probably copper. My inclination would be at $2 a pop to go for it.
http://www.audience-av.com/on_capacitor_dielectric_material.htm
http://www.rfcafe.com/references/electrical/dielectric_constants_strengths.htm
It's not so much the dielectric constant that's important (otherwise we'd all be using electrolytics), more, I think, the dielectric absorption which tends to be related to tan delta or leakage. In those terms, PTFE and polystyrene are top of the heap, with polypropylene second. Paper? Well, there are so many different types of "paper" that it's a very variable feast.
Edit: I've just cut and pasted the first reference you posted to read it in a decent sized fount. The author says the same thing, which is nice.
A link from your second reference gives the following information for dielectric constants:
COCAINE (68°F) 3.1
COFFEE REFUSE 2.4 - 2.6
COKE 1.1 - 2.2
What sort of person does these measurements, and why?
COCAINE (68°F) 3.1
COKE 1.1 - 2.2
I've used these caps and found them quite dull. Definitely not high end, and no use for coupling caps.
I've used them and they aren't bad, certainly less tizzy and strident than the ubiquitous Solen metallized PP's.
hhmm..I found a purveyor of 250V 0.47uf and few left of 0.315uf 250V polystyrene caps, and bought every-last-one-of- them. Cleaned him out. I'll never see those again.
I'm waiting anxiously by my mailbox.....
Hi
I have these caps and I have used them as coupling in my 300b PSU
Certain they have openess and easy on ear no stress but in .my oppinion they colour upped mids,dont sound very dynamic on highs
I found more resolution turning back to my previous Aydyn standard PP caps.
I try next in my speakers crossover Fostex F17 /and Supravox 215s
Papparazzi
Papparazzi
EC8010 said:It's not so much the dielectric constant that's important (otherwise we'd all be using electrolytics)....
It's my understanding there's a rough correlation between low dielectric factor and cap performance. Polyethylene at 2.26 vs. Polypropylene at 2.2, definite possibilities, especially in the context of $2 caps. The second link surprisingly lists a GHz tangent loss superior to Teflon. I imagine much depends on the oil employed in this particular cap. After reading the sonic adjectives used though I'm keen of giving them a try!
And just 'wow' about the Vaseline.
A caffeine addled compulsive?
I found a purveyor of 250V 0.47uf and few left of 0.315uf 250V polystyrene caps, and bought every-last-one-of- them. Cleaned him out. I'll never see those again. >>
Sounds good, but there is CURRENT PRODUCTION polystyrene caps in UK from LCR caps
"We wish to dispel rumours that polystyrene capacitors are now obsolete. Although polystyrene material is no longer available we at LCR have aquired sufficient material to manufacture at the present scheduled rate for a minimum of 15-20 years."
They do up to 630v and up to 0.1uF. Ow bout dat!!
http://www.lcrcapacitors.co.uk/fsc.htm
KBK said:hhmm..I found a purveyor of 250V 0.47uf and few left of 0.315uf 250V polystyrene caps, and bought every-last-one-of- them. Cleaned him out. I'll never see those again.
Yeah, but the combination of 250V..and 0.47uf???? Good freaking luck finding that.
Got them..and DAMN, they's good. whoa! Terrible quality control too. The very large majority (over 50%) are a lousy 0.00% uf value tolerance, and 00.00% matched. The other 40% or so, are 1.00% high, at 0.00% matching. Apalling. 😀
I also have some, maybe not so bad.
http://cgi.ebay.ca/1-5uF-500V-Milit...04327293QQihZ020QQcategoryZ4662QQcmdZViewItem
try this not bad.
and
http://cgi.ebay.ca/0-1uF-500V-Teflo...07111368QQihZ019QQcategoryZ4662QQcmdZViewItem
much better than the 2.2UF/400V
but u should change your design
try this not bad.
and
- Design & Build
- Parts
- Cheap Russian 2.2uF 400V PIO Capacitor
