I've found these cheap 12" woofers:
http://mcm.newark.com/NewarkWebCommerce/mcm/en_US/endecaSearch/partDetail.jsp?SKU=55-1255&N=4
Can anyone find any TS parameters on these? I'm having a bit of trouble. Even without TS parameters, would I be able to make a decent enclosure for them? I'm thinking of making some cheap stereo subs but all the cheap woofers don't seem to have any associated data 🙁
I've found something strikingly similar, but not exactly the same
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=290-360
What's going on? 😕
What's going on? 😕
MCM does have a PDF containing all specs for speakers - http://www.newark.com/product-details/text/mcm/html/cat48/audio_speakers.pdf
-i dont know how this person FOUND this pdf !
They could well be the same. Just be careful because the cheap woofers have more variance in specs.
That woofer would only be any good in a sealed box due to the high Qts. I assume it's stocked by CPC or Farnell and that's why you are checking it out?
You might like to have a look at BK Electronics and their BSB12-100 driver which is broadly comparable with that one.
I've found much better woofers from CPC now I have the TS parameters on almost all that they supply 🙂 The originals I questioned were wild stabs in the dark and turned out to be pretty bad!
- Subwoofers
- Cheap 12" sub - MCM 55-1255
