Chassis mount trimpots?
Need a source for old-fashioned trimpots for chassis/panel mounting. The type you find in old tube equipment. Either the shaft & locking collar type of the shaftless (screwdriver slot) type. Anyone have a source? I need 5k value but I can probably use anything from 2k to 10k.
Any suggestions? Thanks
Thank you Jack!
Yes, that's what I'm looking for. I prefer the two at the right side of the picture with no shaft, as they would be exact replacements in an existing chassis. With the mounting holes 1" apart. Those also have the advantage that they can be operated from both sides, very handy when working on it.
I think I found some at Electronic Surplus, I've got to check with them tomorrow. Their picture is not clear.
Thanks for the help.
