I didn’t see an option for this in the store, but can you do through holes with a countersink or bored out front side? The use case is for mounting amps that attach to the heat sink with a blind hole, so the screw access is from the fin side, not the back side. (Specifically, some hypex UCD modules I have).
— Carl
— Carl
This shouldn't be a problem at all. Please email support@diyaudiostore.com and they'll help to arrange things with Hifi2000. If you can supply a diagram to explain exactly what you want to do, that will help speed up the process.
