Channel switching
Hi everyone, I'm trying to design the footswitch for my new three channels amp, but I'm not sure how to pull this off. The amp has three channels: I have two relays that takes care of the channel switching. When they are activated, they will switch to clean or lead. When these two relays are not connected (i.e. the GND is lifted), the amp is in the crunch channel. Channel switching is currently controlled by a three position panel switch and this works just fine.
In addition, I also added a post FX loop additional master volume which is controlled by its own dedicated relay to GND. I would like to have all this switching in an external pedal: normally I make two channels amp, so I can get away with a simple stereo jack. This time, however, I want to be able to switch between the three channels (clean/crunch/lead) and turn the loop on/off as well. I figured I could use a 5 pin DIN port to transport all the signals I need, but have no idea what's the easiest way to wire this up without using microcontrollers or PICs... Do you guys have any suggestions? I'm a bit lost 🙁
