Channel imbalance drives me crazy
Hi all,
i always thought that my room acoustics affect the stereo imaging when listening to music (right speaker louder than left) until a friend popped in and said that something must be wrong with either the speakers or the amplifier.
After source,speaker,cabling etc swapping we found the problem is with the amplifier.
I fed the input source with 1Khz test tone and set the gain at 1V rms on the speaker outputs.
Left output reads 0.8V and right 1V (no speakers connected).
When i swap the speaker cables on the back of the amplifier the weak speaker sounds louder of course.
I checked everything (capacitors/resistors/bad joints,swapped power amplifier boards, sprayed the volume pot) - everything is ok, the amp is in mint condition.
I believe the problem is somewhere in the pre-amp stage( iruled out the power stage as i used the boards from the power amplifier that i also have and they are identical) or a faulty alps pot
I'm talking about a Roksan Kandy KA1-MK3 amplifier, Roksan asks £199 to repair it plus materials which i find it ridiculous and no way to get any schematics from them.
Find attached some photos and please help before i go crazy.
Preamp
Power amp
Volume Pot
I have a carver M200 that is this way.
And sadly no volume pot to blame on it.
I've swapped drivers and pre drivers left to right and the problem does not change sides.
Anyway you may have a volume pot issue - hope it works for you.
Cool.
Srinath.
When i adjust the knob the 0.2V difference between the channels gets even higher, it doesn't remain the same at higher gain.
The 7805 voltage regulator gets hot (60C) but i reckon this is normal, otherwise i would have other issues wouldn't i?
DC Offset measured 4mV and 21mV.
Don't know how much to set the bias current but i used the power modules from the power amplifier and it didnt make any difference.
The bias and DC offset are measured the same on the integrated and the power amp.
No bad joints, cracks etc
Here is a photo of the power amp (i bought it for biamping):
Transformer supply:
Left & Right Power modules supply
Left connector says nothing , Right one says Preamp L-R out, both terminated on the volume pot.
There is another cable from the preamp to the pot saying Speakers In if you see the photo with the amp layout
The reason I asked you if you used DeOxit to clean your volume pot is because most of the other cleaners dont work anywhere near as good and the volume pot is the first place to look if you have your problem. You should spray both parts of the pot and turn it back and forth about 20 times then try it!
