Alpine amplifier as IRFZ40 in its power supply.
Can I replace them with IRF2807 or IRF3205 without changing gate resistance or any other modifications?
Are they damaged? If they are, IRFZ44 are still available and will drop in with no changes to other components.
You will need to check the gate resistors and verify drive is good before fitting new FETs. What model is the amplifier?
