Changing the speaker in Tham15
hello, and I apologize for my english.🙂
Mam sześć sztuk Tham15. All on 15tbx100 speakers.The drive is Crown cts 3000 dsp
Will there be a difference between 15tbw100 ,15sw115 ?
I will be grateful for your help. I would not like to buy without checking.🙂
More modern, more powerful drivers will allow you to achieve higher SPL if utilized properly, I'm not sure if you are already driving the TBX100's at peak amp level, if so the gain from switching the drivers will be less then if you have more power to give the more powerful drivers then you are currently using with your TBX's.
As for the drivers you listed they are indeed very nice and a clear step up in performance capabilities compared to the ones you currently use (although the TBX drivers are, still, really nice) at the same time it will be a significant investment and I have not tested and compared these drivers.
I would consider the need, is this a curiosity driven endeavor, or a cold hard performance need based on your current business?
I would summarize it like this - unless you have the power to drive these alternative drivers to fully make use of their specifications a change would most likely not be worth the investment.
Sort of a non-answer I'm afraid, perhaps some THAM15 user can chime in at give more useful feedback regarding these questions.
Br / martinsson
