changing opamps on my shanling cdp help ?
has anyone got any instructions on changing the opamps on the shanling cdt 100 or a picture even showing whhere the old ones are i can't find any info on this mod, just that its good, I have my new op amps ready just need to see where i change them thank you
I can't quite recall the physical layout, but the easiest & quickest very nice upgrade you can do is to simply remove the "middle" opamp in each channel, meaning the 2nd of the string of three chips. This will disable the awful GIC lowpass filter, which will improve harmonic layering & separation of instruments quite nicely, and make it overall a bit smoother. Just pull the chip & leave the socket empty.
