The first comment about the CF TQ-15 CF, it is more configurable than the previous series. And it is particularly suitable to be used in professional stage halls. Why talk?
The frequency range of the TQ-15 ranges from 66Hz to 19kHz, which is a range of synthesized sounds from the low bass to the high range within which the human ear can feel 19kHz. Meaning that the sound from CF TQ-15 will be composed of medium to high pitch.
The TQ-15 CF speakerphone is quite aggressive, due to the priority of up to 15 bass combined with 1.75 Treble to create a comic combination, for pure, clear sound. It also has a low level of strength.
Unit: Bass: 15 "x1 / Treble: 1.75" x1
Rated power (@AES) 450 W
Frequency response: 66Hz-19kHz (-6dB)
Nominal impedance 8 ohm
Sensitivity (@ 1w / 1m) 98 db
Maximum sound pressure level: continuous @ 124 db spl
Top @ 130 db spl
Corner of coverage: 80 ° (horizontal) x 50 ° (perpendicular).
Dimensions: 700 (h) x 430 (wide) x 435 (deep) (mm)
Weight: 30.3 kg
You can see more images at:
CF TQ-15 CF
Top @ 130 db spl
Weight: 30.3 kg
CF TQ-15 CF
