centre tap or floating heaters?
I've used centre tap as well as floating w/one leg grounded with a 'lytic cap (2.2-4.7uF) in mic stages, where noise is very noticeable. I'd say there's at best a 6dB favor for the centre tap. However, if you tie the heaters to say, +30V, there seems moot difference between the methods.
a two diode full wave bridge has one side of the transformer cut-off, doing nothing, at reverse phase.
a 4 diode full wave bridge otoh uses the full secondary winding at all times, therefore in terms of transformer utilisation is better the the 2 diode ones.
