Center Tap from dual Secondaries
Between the two options shown are there any issues, advantages or disadvantages?
They are the same electrically. Whether there is any difference in the minutia of how the primary and secondary couple high frequency noise on the mains I wouldn't like to say. There may or may not be any difference there and if there was it would likely be a half of a quarter of nothing.
But probably better still to connect those windings in parallel and feed them into a bridge rectifier. In the circuits you show each winding only supplies current on alternate half-cycles, so in each half-cycle twice the current is flowing for the same output current. This increases heating in the transformer windings due to (I^2)*R.
Not necessarily a problem if the transformer is lightly loaded though.
