Has anyone ever built the center channel speaker described at
HomeTheaterHiFi Project 13 ? It looks pretty detailed and uses audax drivers, several of which have been praised in this forum. This would be my first speaker project to replace a Polk that croaked after 8 years of punishment. I'm an experienced woodworker, and have built several portable amps so I'm hoping those skills will transfer to a new hobby.
I like this project because all the cabinet dimensions, crossovers, etc have been determined, and this is an area I know nothing about.
Thanks for your help!
Steve
Steve
audax cc
While I haven't built this speaker, I have heard good things about it. This is actually designed by either the company or a reputable speaker designer as part of a complete home theater system. Here is a short write up. http://www.partsexpress.com/projectshowcase/audaxhtproject.html You can also normally read about this on the audax site, but it seems to be down at the moment. Check out www.audax.com under projects, USA and you should find it. Quite a good write up there.
Adire Audio Kit LCC opinions
Considering that Audax's US website has been down for 3-4 weeks, I can't get to the plans for their center channel project. As an alternative, does anyone have an opinion on theAdire Audio Kit LCC ? It has twin 8" woofers instead of 6.5s of the audax. At least the plans are available for this one.
Thanks Again
Steve
Thanks Again
Steve
