I have a pair of these I bought for a dollar a few years back and I think they sound pretty good for small speakers . My question on them is the info on each speaker states 8 ohms and I did find one or 2 spec sheets that stated 8 ohms , but I found one sheet that stated 4 ohms . When I disconnected them from my stereo to hook them up to my lepai 2020 I thought "wonder what these show for resistance " and I checked them and I got 3.5 ohms from both of them so I figure they're a 4 ohm speaker . I'm just curious if there was some reason celestion labeled them as 8 ohm speakers when they are actually 4 ohm ? I also checked the woofer and tweeter individually from one of the speakers and got about 3 ohms on the woofer and 6 on the tweeter , so i guess running in parralel thru the crossover (???) would work out to be a 4 ohm speaker . I was also wondering if I could do something to make them work on my sherwood receiver , because that shuts off if it gets a speaker less than 6.5 ohms ( or something like that they specify use only 8 ohm speakers ) . I know I had a speaker with it's tweeter burnt up in it and I didn't know it and my receiver kept shutting down . Losing that tweeter lowered the resistance and was causing the receiver to shut down . Thanks
