I have problem witch C.E.C AMP71 amplifier.
It started to have some elevated dc offset in one channel, the other one was in order but only up tor 5 minutes of listening. After that time DC appears on one of the output and error was indicated.
I'v found that main electrolitic caps in PSU has leak and I have decided to replace them in both channels . After that the amplifier does not start, all relaises are "clapping" and error is indicated.
Could anybody give some advice or idea how to solve this problem.If is possibil
to disconnect this broken channel from input of protection circuit.
