Is it faulty?
I have heard of some folks replacing this op amp and some report an improvement in sonics. I did it on my Philips CD850 (CDM4) but can not tell you that there was a difference. My gear is a lot more revealing now so I may do this one day on my Theta CDM9/pro based drive and see.
I recently fitted new lasers to both mine and a friends unit and both of us believe that besides reading CDRW again, our units sound quite a lot better with the new lasers then with the old worn ones. Scary......
The old ones did not skip as such, they just failed to read table of contents 1/10 times.
Guillaume
Guillaume
Not sure
In those days I used to listen to different types on sockets and I probably used my favourite flavour at the time. AD712, AD847, OP275, NJM2114.
I can not make a "technical recomendation" but would steer toward a OPA2604 these days I think.
Hold it a second! Make sure this is not one of the op amps driving the focus or tracking coils. The servo amp is a special 1 A output current type op amp, and replacing it with an audio type will do no good.
4560 is not very special I thought....
But you may be quite right. 4560 is often seen for higher current applications in audio gear like headphone outputs.
Guillaume
Guillaume
thanks for your inputs.....but the 4560d hardly qualifies for a 1A type or....?
http://www.njr.co.jp/pdf/ae/ae04053.pdf
- Digital Source
- CDM9 servo/control pcb.....replacing the opamp
