Hey everyone,
I have a CDP with a CDM4. Recently the door has started showing problems not wanting to fully eject without human intervention. How should I go about fixing it? Is it just greasing the gears or are there other areas I should look at? Also, if it is the gears what grease would you recommend? Thanks.
Yes, I would say check the gears but also the small plastic pegs that slide in the tray side grooves. Would change the drawer drive belt also.
Good Luck.
R
Good Luck.
R
hi,
new draw gear and belt required about 18 dollars us get them off ebay from china.
cheers alan
cheers alan
Which model of CD player do you have? There are about four or five loader mechanisms that were used with CDM-4 based players, so what is likely wrong depends on the player.
If it is only struggling on the end of its stroke, then it's probably a worn drive belt. A worn drive gear usually results in difficulty and/or shuddering throughout the stroke.
I've got a tonne of spare parts for these players, if you let me know the model I can send you out a replacement part for the cost of postage.
check out this thread:
http://www.diyaudio.com/forums/swap-meet/22940-tray-gear-cd-m4-cd-m9.html
in most cases this gear is broken: ebay item number 400068460224
(without hole for shaft and without shaft)
Very exact advices you will get also from there:
Mr. Heinrich Deppermann
Am Kuhlenfeld 44
D-47199 Duisburg
Germany phone: +49-2841-8808761
E-Mail: heinz.deppermann@cas-germany.com
Am Kuhlenfeld 44
D-47199 Duisburg
