cd100 philips
hello
i have a cd100 he's playing but with a very loud hum(rattling)i replace all capacitors in the power supply,but i stay with the same problem....someone an idea?
I had a same problem.. and I had same idea with power supply capacitors..
The next thing I did was replacing all capacitors.. and the problem was gone.. so I still do not know which specifically was to blame..
hello
i have a cd100 he's playing but with a very loud hum(rattling)i replace all capacitors in the power supply,but i stay with the same problem....someone an idea?I have the complete service manual on pdf...thanks
The hum is caused most likely from the 100uf 25v or 100uf 50v caps in the power supply and the rattling is the spring that is attached to the magnet disc clamp.
