Firstly, when I insert a CD (including CDR) it does not read the TOC then after several times of using the random function on the remote then I can get it to play
Can someone tell me if the laser pick up is worn? Cleaning the lens does not help much...within a few days its back to square one.
I think the mechanism is the VAM 1201. Do I need to change this if so can I replace the above with a better mechanism.
Thanks.
Thanks.
