Cathode Bypass caps - how to choose?
Hi all:
Christmas just a week away and I get a little time to blow up some parts 😀
I expect that I am like many in this crazy hobby - I know just enough about the whole thing to get myself in trouble :xeye: however not enough to say I know what I am doing...
One thing that has me perplexed :scratch: - how to choose a "good" cathode bypass cap. I know that these caps appear in the signal path and they are usually 100uf or better, although fairly low voltage (most of the time). I have bins full of the little blue and black cheapies rescued from many a dead pc board, but I just know that these are not good-sounding caps.
Trying to find a 220uf Solen or Auricap is crazy-making :headbash: AND expensive and the size of these things could require a seperate chassis. So, could one (or more) of you gurus out there help a bit and fill me in on how you select appropriate cathode bypass caps?
PS: Merry Christmas everyone! :santa2:
Blackgates are supposed to be pretty good. Though, up till now, I've been able to avoid using cathode bypass capacitors. If you use these, they still need to be bypassed with a 0.1uF capacitor, and make it a good one like an AuriCap or a Solen.
If you have a convenient source of negative DC, you can use fixed bias on your small signal VTs. If you have gain to burn, you can simply forego bypassing and degenerate the cathode at the expense of some lost gain.
As long as you are within the voltage limits I've used Os-Con with very good results...even bypassed with mica 😀
With all respect to the other posters, decent 'lytics are available at modest expense. Panasonic and Nichicon offer low impedance, 105o C, parts, without "sticker shock". Check the spec's out. These caps. exhibit satisfactory behavior up into the low RF range. 😉
Thanks everyone! 😀
So this is not one of those "right way"things, but trial and error plus some personal preference - cool! I like stuff like that.
kamier - thanks for the link - the Bugle 45 is almost exactly the same schematic as my EL34 SE.
Sy - can you elaborate further on diode bias?
Eli - I agree that most of the Panasonic and Nichicon are good, as 'lytics go, but after trying my EL34 with them in, I removed them, accepted the drop in gain and like the sound much better.
sharpi31 - what are conductive polymer caps, please?
Happy Ho-Ho :xmasman:
Sure. A forward biased diode has a low dynamic impedance and a very constant (and predictable) voltage drop. So you can use that in a cathode circuit in place of the cathode resistor to bias the tube. Unlike the bias resistor/bypass cap combination, overloading the stage will not cause blocking distortion.
You can use different sorts of diodes to get different amounts of bias. A silicon diode will give 0.6-0.7V, an IR LED will give about 1.2V, a red LED about 1.7V, a green LED about 2.0V. The LEDs, besides being excellent voltage sources (and very quiet) also give a nice visual indication that current is running through the stage.
dsavitsk said:
They also cost just a few pennies each, and they sound better than even the best electrolytic bypass.
Even better than a thousand uF worth of filmcaps too...
Even twenty five years ago you'd replace electrolytic bypass caps on small signal tubes (2 to 6V drop across the cathode R) with solid tantulum caps or did away with them altogether and used alterantive methods for biasing the grid.
As for leds, you'd better stock up on the older ones. The newer brighter ones aren't all that great. (See EC8010's post on the topic of LED cathode bias, I only confirm his findings).
Cheers, 😉
Frank, as EC said, the new Agilent jobs are quite bright, but have excellent performance. I'm not as convinced as he is that "bright," "new," and "higher impedance" correlate. I've measured about a dozen different kinds of red LEDs and found high and low impedances in new ones, old one, bright ones, and dim ones.
