Cary Audio Output Transformers PP 2A3
I have for sale these two output transformers. They were pulled from Cary Audio push pull 2A3 amps shown bellow. I replaced them for Lundahl 1663. These trannies have output for 4 and 8 ohms. They were potted in wax, as it is visible on them. They have great bass and mids. They sounded little bit shy on highs and that is why I replaced them for Lundahls. I am posting it here before they go to eBay. Total $ 200 for both plus shipping. They will fit nicely into USPS flat rate medium box. Amp is not included, used for illustration purpose only.
Hi do you know if the transformers would work in a pair of Cary Audio 300b se mono blocks? Thanks Thurston
I cannot tell with full confidence, but please check the Lundahl's data sheet. The amps are 2A3 push pull. The trannies I replaced them with are Lundahl 1663. They allow for SE and push pull connection, and I assume the originals are with the same, or similar specs. If there is any measurement you would want me to make I will be glad to do.
