Carver TX-11 Tuner: How hot is normal?
I got two Carver TX-11 tuners and I got them both to work, but power supplies seem to run hotter than a solid state tuner ought to. I recapped one of them, replaced the 22 ohm 2W power resistor with a new 3W wirewound Vishay PAC series. Still, that resistor heats up to 200-210 deg F (93-100 deg C) in normal use.
The 2SD330 power transistor runs about 140 deg F at the heatsink. All other PS components run at near room temperature.
If anyone out there still owns a Carver TX-11, I would like to know how hot it's supposed to get in normal operation, just so I don't go chasing a fault that does not exist.
Schematics attached, PS is at bottom right, R701 is the hot resistor. Unfortunately I am not skilled enough to calculate the as-designed resistor's power dissipation from looking at the schematics.
All feedback is welcome. Thank you in advance!
The resistor is being operated within its power rating, so if the ventilation is adequate, it should be ok.
Check its value. The actual surface temperature at max power will vary with the resistor design and use.
Nevertheless, you still could replace it with a higher power resistor, or several in parallel.
Perhaps two 43 ohm 3W metal oxide resistors in parallel, spaced apart, would work better.
@rayma
Thanks for the suggestion of 2 // resistors it makes a lot of sense.
Factory-spec resistor was 2 watt carbon. Replaced with a 3 watt 1% wirewound, so dissipation is already 150% of factory spec.
What I would like to know is if 210 degrees is "normal" for this tuner. If it had been running at 210 degrees for the past 40+ years, wouldn't signs of heat be visible? Yet the PCB solder joints etc all look like new, and the old resistor's color bands are nice and bright.
Vishay PAC series' data sheet says operating temp = -55 to 275 deg C, so at 100 deg C we're well within safety. Am I overthinking this?? Thanks!
Power resistors can run surprisingly hot but without problems if you stand them off the board.
Some infrared temperature meters can be fooled by the surface of the resistor if it's not flat black.
If the solder joints were good, they probably knew what they were doing. A mfr can't afford a grossly derated part.
This is the hardest working resistor in the chassis, being just after the rectifier with ripple voltage across it.
I am using a thermocouple probe with my DMM so I think the temperature reading is pretty accurate.
I guess the concern I am dealing with is that some fault / condition elsewhere in the circuit is causing this resistor to run abnormally hot.
If it runs hot by design I'm good with that. I just would like to get some kind of comfort level that it is normal, if that makes sense 🙂
I believe the schematic said 4VDC is across it. Unless you have rather high AC line, or the unit was designed for 110VAC,
it should be ok. You could check the first electrolytic after the rectifier, if it's way low, the ripple voltage would get larger.
Reactions: MFRD
The specs from Carver say 110 / 220V, but the voltage selection switch inside the unit says 115V. AC is pretty stable at 121-122V around here.
Specs also say that max power consumption is 15W.
I recapped the PS, all brand new electrolytics (interestingly, many of the 40-year-old Rubycons measure better - lower ESR - than the new Nichicons!).
OK, so I have two of these Carver tuners. The above write-up was about - let's call it tuner B
I since reworked tuner A to the same standard as tuner B
I powered tuner A, everything worked fine, but R701 shot right up to 320 degrees! That's definitely not normal. On the other hand, Q701 ran much cooler than in tuner B, only 80-90 degrees.
I dug into it and found D707 shorting to ground. That prompted me to test Q702, which was shot too.
I'll update the thread after my new parts arrive
I have both a Fluke infrared, and a thermocouple that plugs into my Brymen DMM. The Fluke measured only half as high a temperature as the thermocouple did.
After some experimenting, it looks like the Fluke does not like curved surfaces like the resistor's. On flat surfaces the two track pretty close.
I think I need a thermal imaging camera 🙂
Closing the loop on this thread...
I did get a thermal camera (but I'm returning it - FLIR One, it's a right piece of crap, so cynically defeatured by its manufacturer as to be rendered useless to force you to "upgrade").
Anyway, since my last post I replaced D707 and Q 702; recapped both power supplies in both tuners - the main PCB and the mezzanine PCB, aka "multipath card" each having their own PSU.
Replacing D707 and Q 702 in tuner B brought its temperature down in line with tuner A; but both still high at ~100 C.
I pored over the PCBs and schematics until convinced nothing was wrong with my two units, they just operated as designed - rather poorly designed. So I figured I'd try to mitigate the issue by quadrupling the overheating resistors' power dissipation (R701 on the main board, R286 and R287 on the mezzanine board).
That worked better than expected: R701 dropped 34 C from 100 C to 66 C; R286 and R287 from (respectively) 73 C to 53 C, and 55 C to 44 C.
Meanwhile, power transistors (Q701 on the main board, Q13 and Q14 on the mezzanine board) stayed at pretty much the same temperatures as before the resistor mod.
AC power draw is above the 15W factory spec - 17.2W and 20.6W respectively, but unchanged vs pre-mod, so who knows how accurate that 15W spec even is.
All in all I'm pretty pleased with the outcome, it was a cheap and easy mod and it seems to work pretty well. Otherwise, all functions work as intended in both tuners. Saved stations were kept in memory even after the units were left unplugged over a month.
Thanks to all who responded. Glad I saved these two from the dump. These tuners sound pretty sweet!
