Carver TFM-15 / TFM-15CB amplifier alignment
I recently repaired my two TFM-25 and aligned the channels as described in the service manual (it just involved measuring voltages at the test points while adjusting some variable resistors).
I was hoping someone could explain how I can perform the same alignment on my TFM-15 and TFM-15CB. They should both require the same kind of procedure, and the information should be in their respective service manuals.
Thanks for the help!
Angelo Brisimitzakis
