Carbon material cables
hi gentlemen,
I would like to build my own analogue interconnect and loudspeaker cables made with carbon. I just don't know where to get carbon material which suitable (flexibility, conductivity, etc) for cable assembly? has anybody made something like that?
any help appreciated!
best regards
Traditional automobile spark wires were a loose linen thread dragged in powdered carbon and then rubberized. The high resistance damped some radio interference.
We usually assumed 1,000 Ohms per foot. You may want <1r/10'. So it has to be 100X the diameter. About 10 inch diameter linen "yarn".
Aquadag is another Carbon "conductor".
Sorry your first post is not going so well, stahlhelm!
There are many allotropes of carbon, one being diamond if you're feeling flush!
Many engineers once believed diamonds could not conduct electricity due to a tetrahedron structure made by covalent bonds between carbon atoms, which doesn’t allow for free electrons to carry current. Most natural diamonds are electrical insulators, but by manipulating the properties of diamond, it is possible to introduce controlled dopants that let the material conduct electricity quite effectively.
Adding boron to the lattice make diamonds blue at low concentrations and opaque at higher concentrations. At these high concentrations, diamonds behave like a metal and become a good conductor of electricity.
10 Myths About Diamonds | Machine Design
the reason: I heard a carbon/graphite (I don't know exactly what material it was made form) speaker cables and it blew my mind. it was absolutely fantastic and the best so far I heard. I want to build something like that because it is very expensive. I want to experiment with carbon/graphite DIY cables.
1) placebo effect.
NO WAY a wonder cable can make your amp "sound better" than same length of good old copper cable. NO WAY.
Even less in the superlative tones you use to describe it, so you are clearly "listening with your wallet"
There is a reason cable threads end in chaos and are closed down.
The ad brochure for the cable you mention must certainly "mention" carbon graphite or any other wonder material, be certain that if it worked at all (meaning it successfully connects an amplifier to a speaker) then it has copper inside, or maybe Aluminum.
Even Silver if you feel fancy.
MAYBE the insulation contains such materials, that does not affect the sound.
By the same token we talk about a Teflon cable, PVC cable, cloth and rubber cable, etc.
In all cases we are talking the insulation, not the conductor.
Carbon strand interconnects have been around for a very long time, nothing exotic about those. At some stage i also had a pair and although not truly horrible they didn't stick around for long. They also had substantial resistance but whether it was 10 or a 100ohm i no longer remember.
Cannot imagine carbon wire being of sufficiently low resistance as to be usable for bass driver duties. Tweeters and midranges are usually resistor padded, so there it may shine as a combined cable/risistor. Especially if one likes the carbon sound.
Hmm, a brand new forum member first posts start drifting off into praising a commercial cable.....
The reason carbon worked in HT leads is that the kilovolts could blast through any momentary bad connection and nobody cared if the spark current was slightly AM modulated by engine vibration
