What would be the proper way to series the secondaries of transformers in basic two transformer based amplifiers?
I've done it successfully except struggling figuring out grounding the secondaries at this point.Example being for the scope ground.
I'm assuming I have no phasing issues seeing that the voltage essentially doubled by connecting the secondaries.
Could someone give me the necessary guidelines to connecting these style 2 primary 2 secondary windings style transformers in series correctly and how ground of the secondary is handled.
Still wondering if the firing order for the 4 primary windings is crucial with the secondaries series'd.
The primaries aren't connected in series. They're typically driven by their own FETs for each transformer.
The first secondary is normal (two center-tap windings connected and used as the secondary ground). The secondary windings of the second transformer are isolated from one another and each connect to the output of the first transformer.
Sorry for not being more descriptive on the part where I mentioned the primaries.But like always,thanks for reply.Exactly what I needed.
Using a portion of an old soundstream amp to provide DC buss for sine wave inverter.
