im working on this pioneer gm-d9601amp
with just my power and ground wire conected the amp draws a lot of current
no remote wire conected at all
also with my meter set on dieod i put it on the negative and positive terminals
and the number go up showing that the caps are charging
im not shore what to check ??
could it be fake irf3205 ???
it needed 4 ifr3025 for the power supply
all gate resistors are fine 47ohm
Defective drivers for the FETs could be a problem. If you power it up for a few seconds, do the FETs get warm/hot?
