Hi All,
I'm trying to build my own car audio amplifier but am having a hard time finding a distributor that carries the large +12-V input and speaker output cables... Does anyone know where I can find something like this?
Thanks!
-=Randy
Thanks!
-=Randy
R U kidding? Do you mean, the cables or the connectors. Try your local car audio shop or partsexpress.com...
Opps: I meant the large power connectors - NOT the wires. I checked partsexpress but didn't see anything. Do you guys think using pipe fittings molded into epoxy would work?
Thanks,
Randy
Thanks,
Randy
Connectors
Electronic goldmine carries terminal connectors...and lots of other goodies...
http://www.goldmine-elec-products.com/prodinfo.asp?number=G14092&variation=&aitem=25&mitem=43
www.digikey.com - search for barrier or terminal block
www.mouser.com - terminal block
Robot underground sells the good stuff (Ebay), but they are not cheap by any means, and detract greatly from the DIY purpose.
I'll tell you how I handled power and ground on my monster amp...I ran a long length of cable from the PCB to a distribution block. There's no high power connection at the end of the amp at all. Simplifies end plate contruction as well. Like old school stuff...
Randy Knutson said:Hi All,
Thanks!
-=Randy
You should consider ebay sellers for the cable for sure. Check out the seller Trucktunes, I had great experience buying from him. 25ft of Esoteric 8ga was $5. He also sells 4ga stuff as I recall.
- General Interest
- Car Audio
- Car Amplifier +12-V Connector Question
