Car Amp Grounding
I've bought a car amplifier and their necessary cables and planning to install them inside my car. Now i am thinking about the amp grounding ....
Can i connect the ground terminal of the amp to the nearest part of the vehicle chassis .... or should i use a large gauge ground wire to connect it from the amplifier to the battery?😕
Any suggestions are very much appreciated. Thanks
Where's the battery? In some case going straight to battery will be better-most of the SPL guys will do a run to the battery as less voltage drop then to the chassis-only really a consideration with large power systems.
I sell car audio and my biggest issue with amps is poor earths-actually had one guy tell me the amp I sold him was POS and when I checked why it wasn't working he was trying to earth to MDF!
Generally straight to the chassis will work fine-just make sure it's a main part of the car and not a spot welded on pannel. Also make sure you sand back to bare metal and then drill through (making sure no brake/fuel lines etc are in the path) and bolt down, Some spray paint on the outside of the car and vaseline inside should prevent any corrosion.
