Caps in crossover for midrange question
Hi Thanks for reading I'm using a single 10uf cap in series with an 8 ohm midrange unit, giving a crossover frequency of 2khz @ 6db/octave
I had bright idea of replacing the single 10uf cap with 10 x 1uf wima polypropylenes, i thought with so many caps paralled up it might give lower esr and reduce some of the other undesirables elements of caps. Now the sound is all weird, sounds wrong, i don't know what is going on.
Have you tried anything like this before, or heard anything
Measure impedance of a 10uF capacitor. Save it for comparison purposes as a .zma file.
Measure also all of the smaller capacitors connected together and save the file in the same way.
Load these two up in a simulator to inspect how they align.
Reactions: goodguys
