Capacity of L'Art du Son cleaning fluid
I bought a bottle of L'Art du Son cleaning fluid that I heard it is very good. Although the bottle indicates it can dilute to 5 litres, I cannot find any indication on what is the actual volume of the concentrate. I am not going to dilute it to 5 litres all at once because it will produce precipitate when diluted and unused in one week.
Does anyone know what is the actual volume of the concentrate bottle?
No idea but go to your chemist/pharmacy and buy a big 50 ML seringe and a new (bigger) bottle. Use the seringe to suck up and transfer the fluid to the new bottle and calculate the total volume moved.
Afterwards you use the seringe to dose the correct required amount with your less then 5 Litre dillution.
