Capacitors for Crossover
Hi, I am wanting to do a minor upgrade of the caps and resistors in a pair of PSB B6 speakers just for fun. The crossover uses 15uf 100v and 12uf 100v electrolytics.
My question is, can I use non electrolytic film caps with the same capacitance but higher voltage, say 250v to 400v?
I am also replacing the cheap sandcast resistors with Mills of the same values.
Thanks!
I ended up buying 15uf 250v and 10uf 250v Claritycap CSA's and Mills resistors. It should make a nice improvement in sound over the stock cheap electrolytic caps and sandcast resistors but you never know when swapping parts.
Any recommendations on hook up wire? I was thinking about duelund cotton in oil.
