I am new to valves, So obviously I do not understand them.
Having said that, I have been handed a preamp to 'update' (yes some of the parts really do need replacement due to eminent failure).
I believe it is capable of 12v output.
My questions are in regards to c2 3uf/200v film cap.
What voltage does it actually need to handle ?
How much frequency response change would it cause if it was changed to a 2.7uf or 3.3uf ?
Thanks 🙂
Thanks 🙂
C3 need only be somewhere between 2uF and 4uF, and the value is not critical.
However I would use a 400V part.
If your using valves and dont understand them read and inform yourself.tubes are easy to understand and use in comparrison to silicon.
It is good practice to select a capacitor that can withstand the full power supply high voltage. This way, the device connected to the output will not be damaged by a malfunction such as a short circuit inside the valve.
The LF roll-off frequency is linearly related to the C value. Lower it 10% (3.3 to 3) and the LF roll off drops 10%. Etc.
BTW, film caps are extremely stable and typically never need to be replaced.
Spend your money where it counts.
Jan
Jan
