Howdy folks,
Quick question...
I have an el cheapo Chinese made "Vox" 4 watt guitar amp and am adding a Mercury Magnetics I/O trans, choke and component/circuit mod upgrade.
Thinking of upgrading the electrolytic caps, to something that might be quieter and a bit more hifi, and also dry for long term lower maint.
Any thoughts on compounds i.e., tantalum, PTFE etc?
Thank you,
John
Quick question...
Thank you,
John
any good quality electrolytics from a major western manufacturer will do. audiophile grade is just plain BS go for a 105 degree C . if you feel that you must.
either way a crappy unit is still a crappy unit you can only try to make it Less crappy. the critical parts are OPT´s and circuit topology.
V4lve
V4lve
V4lve
Agree ! 😀
I would always go for 105 degrees C over lower ratings. The spec is not just about the working temperature - it is to do with the ability of the part to operate over time at any elevated temperature. Thus a 105 degree part running at 50 degrees will have a much longer life than a 85 degree part run at 50 degrees. Major eastern (esp. Japanese) manufacturers are also good.
Yep!! Nichicon makes good caps. I like their Muze KZ series for the (very few) electrolytics I use in the signal path. For lower value caps, I tend to stick with polypropylene caps.
Just buy the caps from a reputable supplier like Digikey, Newark, Farnell, etc. The eBay specials are usually not worth it.
~Tom
Thanks folks!
Those are the brands I typically use, as well as Hitichi in the past and I like WIMA in the microphones and mic pres etc.
I will check the ratings on the parts and the brand parts as well, they are certainly cheap enough.
Digikey are my main supplier, but that's where I got into trouble in the first place...
So many kinds of nice parts, like a candy store, lol *embarrassed*
thanks again,
John
thanks again,
John
For those that think hi end caps are BS, well...you probably have never heard a decent cap (Mundorf or Jensen) from the sounds of it.....(talking power caps here)
To the OP question, if you are referring to power caps, seeing It's a guitar amp maybe F&T is worth a look in, these are not a so called "audiophile cap" just a very good cap.
For the signal path film/foil caps where possible, again you don't need to go crazy, the older type Hovland Musicaps are nice and don't cost a fortune, and the Obligatto MPK's are very affordable and have nice dynamics.
Edit:At the end of the day you want parts with sound signatures that complement each other, just like you match source > amps and speakers for best sound, It's a similar deal with component parts, doesn't matter if they are cheap or expensive, the same matching is needed for the sound you are looking for.
Bet I get flamed by some here for the above, but that's sweet 😀
Yes it is, I even mentioned that in my post.
And I never recommended any so called "audiophile" caps, so I don't know what you are trying to point out?
When It's not a guitar amp I'll be mentioning names like Deulund 😀 unless they have defined a restrictive budget 😉
motor start caps in power supply, motor run caps in bypass/coupling if you want to try something different. maybe switch in/out bypass caps on cathode circuits. btw wima suck in a lot of tube circuits. orange drops are better.
- Design & Build
- Parts
- Capacitor Substitution
