Hello to all,
I'm just doing some capacitors upgrade on the supply, and DSP board and just found that on the I/O board, based on the schematic available onthe yahoo group, for Rev. E, the board is missing the capacitor C7 (47u/25) on the 5V which, with a 10r, is feeding the realys that switch the A input from analog to digita and the C input from line to mic.
Mine is Rev. G
Could you confirm this?
Using the scope I found tha when the relay swithces in a greater amount of noise is seen on the 5V, and this is the same voltage that is feeding the CS8420 ...
I was thining about adding back a cap there, whic could "dump" the noise ... if it is generated by the coil of the relay.
Thank you,
Mauro
Mine is Rev. G
Thank you,
Mauro
Why that could bother you? Relays commute at power-on, if change source or mute something, not in the program.
he explained why it bothered him.Mambo said:Using the scope I found that when the relay switches in, a greater amount of noise is seen on the 5V and this is the same voltage that is feeding the CS8420 ...
