Can someone recommend a source for vertical mounting clamps for 2.5" capacitors? I need 4 of these.
Mouser Electronics does not stock them anymore.
I fashion these from sheet aluminum using a pair of tin snips. Just use a little math to determine the diameter, lay out a pattern for the tabs. They work as well as the manufactured variety.
Or you can buy them from Allied Electronics www.alliedelec.com -- just search under capacitor mounting hardware.
Here's one left over from a bunch I made back in the 1980's (it was for an SP-3 clone :
Check the electrical dept at Home Depot(or Loews). I use 2" EMT mounting clamps . Old timer electricians call them Mae West clamps because of the shape. They work and look great as long as you don't mind bolting them to the side wall of your chassis. Used them when I built my ESP-101 amps. Best part is they cost 69 cents each.
Steve at Apex jr. has them- http://www.apexjr.com/
Also, JPS capacitors has them- http://stores.ebay.com/JEA-CAPACITORS
I don't think they are shown on the web pages but if you call you can get them.
