Capacitance Multiplier Power Supply
some builders who have adopted the multiplier recommend and other say it interferes with the sound.
It will not cost much to try but expect to have to undo it.
A conventional Transformer + rectifier + smoothing is hard to beat.
Great with ClassAB (low hum at quiescent state). Great when asked to deliver lots of power, and can withstand enormous overload when the operator does something wrong.
hello.
there was a thread: 70w class a amp on jan. 02 ,a few days ago.that amp uses one.
i think it is a simplified version of a simple discrete voltageregulator - without a zenerdiode.
once an amp began to oscillate -that was the only problem i ever had with it.
greetings..........
Redshift187 said:
Has anyone here ever attempted to build a "Capacitance Multiplier Power Supply"? I was reading about it here:
http://sound.westhost.com/project15.htm
Note that while the title says for Class-A, it discusses using for Class-AB as well.
Looks very interesting, and not too difficult to build.
Yes, I built a variation of it.
Post #41 of this thread has the schematic of it
http://www.diyaudio.com/forums/showthread.php?s=&threadid=111775&perpage=25&pagenumber=2
Here is a link to a pic
http://diyaudioprojects.com/Gallery/displayimage.php?album=4&pos=22
As recommended, its laid out just like the schematic
I don't have the background to make any audiophile comparisons, or technical comments, but it sounds good to me. I'm using it in a Class A amp that get listened to weekly. I enjoy it.
The only way I was able to get rid of the hum in a Elliot DoZ amp was to build a cap multiplier. But, I think they may not be a good choice for a Class aB amp...the variations in the load mean that there will be a lot of power wasted in the pass transistor of the multipler. Try to reduce the wasted power and you run the risk of sucking the multiplier dry with heavy loads.
The cap multiplier is a cool idea for Class A use, but a problem with Class aB.
