Capacitance in X-overs
Does anyone know if there is a benefit to using off size capacitors to get a desired value for the purposes of a crossover?
Ex: Target is 80uF. Is it 'better' to use two 40uF versus a 20uF combined with a 60uF? Is there a simple rule, or calculation?
Thanks.
Sounds good. Thank you!
Our of curiosity, is there a minimum recommendation or standard forVDC?
I was going to use 250V, because they are easier to find in audio grade 1%. That will give a fairly good Voltage buffer, as my amps rails are ~67V. Does that seem reasonable?
