Cap vs DC servo in global NFB tests
Following discussion in the other thread, performed a few experiments.
This is definitely not a comprehensive research, but a few tests, rather representative though.
Tests are based on my highly lineat symmetric prototype, mentioned here some time ago. Capacitor value - is just the one I had in hand, but enough for 1kHz test. Output signal amplitude is 20v in all tests.
1-st test - 33uF 35v cap serially with 1k resistor as part of global NFB. Positive wire of the cap is connected to the resistor ("signal" side), negative - to the "ground". Output DC offset with no signal comes to -18.5mV, offset at the capacitor -0.66mV (negative offset at the positive cap wire).
See the spectrum at pic.1 - rather low, but clearly visible 3-rd harmonic.
2-nd test - the cap is "flipped over". DC offset at the output is -17.2mV, at the cap -0.61mV. This time the offset is the "right" one for the cap.
See the spectrum at pic.2 - 3-rd harmonic is roughly 6db lower, than before.
3-rd test - finally, no cap, DC servo is in place. Offset at the output is less than -1mV. Spectrum at pic3 - that's what it's meant to be.
Conclusion - if you don't mind slight THD increase, the cap is a simple working solution. As for me - I prefer minimizing the "bad" 3-rd harmonic. DC servo integrator is my choice.
Another advantage of DC servo - in case DC coupling of the power amp with pre-amplifier, if some offset is coming from pre-amp, DC servo will compensate it (within certain limits, but still), so that the offset at the speakers will be close to zero. Which is always good.
Thanks.
Half the distortion when the tiny DC bias is of the correct polarity.
20Vac across 1k and 33uF is a mighty high power when the upper leg of the NFB might be seeing 400Vac (gain of 21times).
100Hz and 40Hz @ 5Vac might be more revealing.
Do you have 4 to do a series parallel combination for the same 33uF at these lower frequencies?
Two things will lower the distortions across the cap: Use a bipolar cap and make it reasonable big to lower the crossover frequency. Less AC across the cap results in less distortion. Now given cost and size of a larger bipolar the servo solution becomes attractive. On the other hand a servo takes some time to settle, so you will have a bit of DC at the output at turn on, resulting in a "turn on thump".
