I am kind of knew building speaker xovers, so i am currently searching for the parts i need to make the Proac 2.5 clones.
In the crossover design it has a capacitor of 3.4uF and another of 7.0uF that i cant find....
Does it have to be exactly the same value, or will i just use a 3.3 instead of the 3.4 and a 6.8 for the 7.0 ?
I think not or the designer would not place those values, right?
So...what should i do ? Can i just put the 3.3uF in parallel with a 0.1uF in order to have 3.4 uF ??? Will this degrade the sound ?
Tx a lot guys...
F.T.SA
Tx a lot guys...
F.T.SA
You got it.
Yes,
You have it right. Put the 3.3 in parallel with a 0.1 to get 3.4 uF.
I'm guessing nearly every crossover ever built has some capacitors in parallel just for this reason.
Yes,
I am also in the process of building a proac 2.5 clone and am using the XO published by Troels Gravesen. He has a very simple XO that uses fewer parts than the one by Al M.
Since this is my first DIY project , I wanted to keep it plain and simple. I ordered the XO and had them delivered to me assembled from madisound. The total cost was abt $120.
But if you just want to use the old version, then yes, 3.3 and .1 in parallel will give you 3.4 🙂
Cacophonix
PS: Cutting MDF to the right measurement is such a pain. I pretty much screwed up the 8x4 sheet and will be buying another sheet. This time I HAVE to follow the rule - Measure twice, cut once!
Cacophonix
Are you taking about this xo with the notch filter ?
http://www.geocities.com/diyproac25/images/Jacq_Troels.gif
This is what i intend to do, and it seems to me that it has a 3.4uF in the tweeter and 7.0uF in the woofer .... ???
So....what xo do YOU have ?
F.T.SA
F.T.SA
I'm using the XO described in :
http://members.chello.se/jpo/2_5_clone_without_notch_filter.pdf
This one uses a 3.9 uF, 4.7 uF and 6.8 uF which are standard values.
