Can you recomend a good first phono pre-amp?
Hi guys.
I originally posted this in the analogue line level forum by mistake:
I am currently re-furbishing a Dual CS 505-2 turntable that I bought from a friend. I have had to fix an internal microswitch, re-wire the rca wires, dismantle and re-grease everything and generally have a lot of fun making it work.
I'm now looking forward to listening to some of the Radiohead and Pixies albums my other half bought me for Christmas to start my collection!
I am currently building a MiniDSP 2x8 based pre-amp and crossover and would like to include a MM phono pre-amp stage in the same case.
Can you recommend me a nice quality kit (or pre-built circuit) and power supply? I have used a cheap Maplin SP-24a with reasonable results but hope that I can do better with a kit and get the enjoyment of building it myself.
Many thanks in advance.
Jai Stanley
I have a strong recomendation for the Phono RIAA application note from LME49720 datasheet. You can use much cheaper opamps instead of LME49720 like OPA2134. I tested it and sounds very good to me and its simple and cheap. I'm using with two 9v batteries.
Almost any opamp based RIAA preamplifier is virtually the same. You get either a two stage setup with a passive correction or one stage with correction in the FB loop. Sometimes you might find a combination of those two things. And that's it. The quality of the preamp is in this case mostly determined by the quality (and complexity, and the cost) of the power supply. Simple. I often find it rather amusing when people try to make a simple opamp based design look like a rocket science and charge the poor customer with a 4 figures price tag. When you look inside you find two 7815; 7915 regulators feeding the whole thing 😱
