Hi! My fender mustang 2 amp has recently stopped working due to the input being broken, I've had a look inside and the input/footswitch circuit is easily taken off so would be ideal to swap that for a working circuit online. Problem is I can't find one anywhere, I can get the actual input component but that would require burning the old solder away and re-soldering the new component on! (Which I can't do)
Thanks in advance!
Thanks in advance!
Not sure what you are asking for. If your input jack quit working, it may just need to be resoldered underneath. But if the jack is broken, it has to be desoldered from the board, and a new jack soldered in its place. If you can't do the solder work, no shame in that, but you will need to find someone who can.
