I'm going to incorporate a Dayton SD215-88 ( http://www.partsexpress.com/pe/pshowdetl.cfm?&Partnumber=295-480 ) into a portable boombox. I'm going to power the DVC sub with a 2 channel amp. I dont have any impedance plot except for the Dayton provided one. I'm wanting to cross it over at around 200hz @ 12dB. Can anybody help me out? How close could I get by using the Dayton provided impedance curve?
Thanks!
Thanks!
Greets!
Pretty close once you add a zobel to flatten it, but the 3.75 ohm non-inductive power resistor and 85 - 88 uF cap's going to be kind of large to fit in a boombox, not to mention make it run hot, so a line level XO seems a better choice: http://www.t-linespeakers.org/tech/filters/passiveHLxo.html
GM
GM
Well, passive filters at 200 Hz is often problematic due to the impedance curve of the driver. Below is an example of a cookbook filter (green curve) and what happens when it is applied to the complex load of the driver. When the values are "fiddled" a bit, it looks a bit better (blue curve).
I think this highlights the need for simulations when designing passive filters 😀 . The impedance of the blue system is probably too low to be useful, though.
I'll try the PLLXO route then. It seems easy enough (even for me). I have no idea how to choose R1 though. But if I were to choose 10kohms would this be correct for a 2nd order lowpass @ 200hz?
R1 = 10kohms
C1 = 80nF
R2 = 100kohms
C2 = 8nF
Is this right?
R1 = 10kohms
C1 = 80nF
R2 = 100kohms
C2 = 8nF
Is this right?
GuyPanico said:I'll try the PLLXO route then. It seems easy enough (even for me). I have no idea how to choose R1 though. But if I were to choose 10kohms would this be correct for a 2nd order lowpass @ 200hz?
R1 = 10kohms
C1 = 80nF
R2 = 100kohms
C2 = 8nF
Is this right?
You pick R1 and R2 as a compromise between insertion loss and the impedance your preamp sees. You need to know your preamp's output impedance, and your amplifiers input impedance, too get an idea of how much wiggle room you have.
For example, if your amplifier's input impedance is 100kohms, then your above filter would result in about 3db insertion loss. If the input impedance is 10kohms, then insertion loss is closer to 11db. As you reduce R2, insertion loss gets smaller, but so does R1.
Since R1 is the lowest impedance the preamp will see, you can't reduce it forever. I think 10x output impedance is a minimum, but hopefully someone with more knowledge than I will chime in with a better answer.
Dan
Hi, is there no way you can use an active filter before the amps. You will get a much more predictable crossover and better control of the drive units as there will be less resistance between the amp and the driver coil.
Regards,
Andrew
Regards,
Andrew
gfiandy said:Hi, is there no way you can use an active filter before the amps. You will get a much more predictable crossover and better control of the drive units as there will be less resistance between the amp and the driver coil.
Regards,
Andrew
+1 active is always better than passive... cheaper and better sound quality. 🙂
I'm in planning stage of similar project. Planning to use a DVC sub woofer. Was going to use active filter but concerned about Power supply. Going to run car radio with ac power supply. An active filter would require another amp and would be considerable challenge to power supply.
See if this helps. http://www.apicsllc.com/apics/Misc/filter2.html
davidlzimmer said:I'm in planning stage of similar project. Planning to use a DVC sub woofer. Was going to use active filter but concerned about Power supply. Going to run car radio with ac power supply. An active filter would require another amp and would be considerable challenge to power supply.
AC PSU? Look into getting +-5v from your cars electrical system, it shouldn't be too hard. 🙂 Try not to use AC in your car unless you are making your own SPMS.
Maybe I wasn't clear. The project is a portable boom box. Based on car stereo which will give me FM, CD, and external inputs such as MP3 player.
Plan to use AC power instead of battery. Tho, a batery could be used if no power available.
Am now considering a matched component system and be done with it.
Like this
82db speaker and occasional battery power are incompatible.
I must come into the definition of an oldie because I don't know what a boom box is.
Or never had any kids 😉, my daughter was pestering me to make/buy her one at least 30 yrs ago. Anyway, portable stereo system: http://www.secure-internet-store.com/products/product-view.asp?prodID=5769
GM
GM
The thing is, for not a great deal more than the list price, I think I can build something with much more power and better sound that will have an aux input for my and other's MP3 players.
BTW, I'm 62. Maybe I AM too young for this project. 😀
The project is for Beer and BBQ parties. Not to be carried around!
Or less, I've built several portable party systems with a used car audio unit/co-ax drivers for next to nothing. I imagine using more recent deluxe systems with their considerable DSP will sound better overall.
GM
GM
Yep. Funny thing the whole idea popped in my head when I saw a cheap DVC sub woofer by Goldwood.
I think a pre engineered component speaker and a good CD receiver with an aux input will do fine and be much simpler.
- Subwoofers
- Can somebody help with a simple 12dB filter?
