hy i have projectors witjout the lamps
and i have 3 projectors with lamp but burned power supply
the lamp in that projectors is UHP150W 1.0 232-0207-01 made in belgium can i use that burner in projector that uses the lamp philips TOP 246 G6 uhp 200/150 1.0 00x004015 x stands for number that i canot see it is ereased...
how to find out is it AC or DC or witch voltage it is using???
Yes you should be able to use it. All Philips UHP is AC. The operating voltage are more or less the same on all projectors. The only thing differs is the striking voltage but I believe it should work. Worst case scenario, it may take more than one attempt to strike the burner.
