can i replace a stereo pot with a 1 gang pot
on this volume board:
Balanced in/out 256 steps volume control board passive pre-amplifier stereo
the pot need to be linear, i'm using a an alp stereo log pot and it trip the relays easily
i'm having a hard time to find a 2 gang pot linear that fit size wize like an alp pot?
(i do not need to balanced my signal)
thanks
Martin
finally the manufacturer answer me....
Hi Martin,
Yes you can use a high quality single gang with value 20K - 30K and linear scale.
Best regards,
Stanton
JIMS AUDIO
Reply
Your previous message
thanks
can i use a precision pot with one gang only (solder the two circuit together)?
Martin
As far as I understand relay-attenuators (I am using something similar from ELMA for the first time...), you can use whatever potentiometer that triggers the relay-control. The elma controls both channels at once (thus, a single-deck pot is good enough—for the ELMA. Are you sure you can control left/right independently?)
If a linear pot is required/recommended, the logarhithmic function is (most probably) embedded in the resistor-chain. Controlling the unit with a logarithmic pot results in "doubling" or adding up the logarithmic' steps… (volume-control becomes awkward).
Multiturn pot, precision pots don't make much sense, because these are in fact a variation of stepped attenuator with a finite number of positions. (a pot's position of say, 0.7111 would be the same as 0.7001 or just 0.7)
Same with a multiturn— plus you haven't visual feedback of the pot‘s position, unless you connect a display of sorts (digital display or those nifty, analog multiturn potentiometer with gears which name I have forgotten... something like that)
