Can I Replace a Mechanical POT With A Digital One On My Delay Pedal?
Hi All,
I'm inventing something for the effects pedal market. As in distortion pedal, delay pedal etc. I know only a bit about electronics and circuitry. Engineers will help me later. For now I'm just trying to understand this:
Is it possible to remove any given pot from a pcb, as in the "Time Knob" on a delay pedal, and replace it with a digital means of parameter control?
If so, how?
Can the now empty points extruding from the pcb be connected to a DAC of some sort, thereby opening the possibility digital control?
I'm knew to this forum thing.. please be gentle. 🙂
Thanks in advance.
Pete
Also: it depends on what the pot does.
A "volume control" type pot with one leg grounded or referenced to ground is easier; a fully floating "isolated from everything else" pot such as a mechanical carbon track is harder.
In fact, designing some kind of digital time/speed/whatever is probably much better than trying so replace an existing carbon track with a brass wiper ... which was already suggested above.
