Can I Parallel PCM56's ?
Yes you can, I have 4 per channel still,
if it is inside a cd player, make sure the psu can deliver the current.
Some players have shuntregs that are weak.
Connect MSB adjust network on one chip per channel only. Parallel V-out pins could make some problems, better use passive I/V and parallel I-out.
Reactions: Alexium
