Can a classic bass reflex alignment work as a cardioid?
I ve seen other ideas at diyaudio with mesh/stuffing/holes etc in enclosure to implement a cardioid. Can ONLY acoustic bass reflex work as effectively? The goal is constant narrow directivity down to 250Hz.
Lets take a 6" midrange, if we put a small rear enclosure and port it sufficiently high (at around 2Khz) with several holes around the edges then does it yield a cardioid? Tuning could be achieved by observing the impedance.
The bass reflex alignment should provide the low pass and the corresponding delay.
What your describing sounds similar to the various "passive" cardioid box designs. normally they use an aperiodic enclosure, and apparently can work pretty well. My gut tells me that it would be very hard to get the design to work the actual ports (because the output from them is not wideband)
To become cardioid, leakage area must be sufficient and evenly distributed on sides. Basically pretty much same principles as dipole, but some obstruction or phase rotation/delay is needed to block backside radiation 150-10 degrees.
"Keyser" (who's now at Dutch&Dutch) made some nice experiments and measurements some time ago, and so did "kimmosto" even earlier. Finnish loudspeaker companies Gradient and Amphion have used cardiod midranges for ages!
2-way: Waveguide + Cardioid-like
Cardioid bass
Ports of resistance enclosure could be filled vents. For example single column on both side walls. But it should stay as resistance box i.e. resonance which would attenuate cone signal should be totally prevented with port filling.
