Hi
Anyone know how to upgrade CA Dacmagic. I found this link but don't know what are the specs for substitute components?
Google Image Result for http://www.audiocominternational.com/images/dacmagic_azur_800x600_3.jpg
thanks!
thanks!
The replacement parts are listed on the page you link to. You'll see the values that you need when you open your Dacmagic; there's not much space in there.
I've added two audiocom regulators, a bigger power transformer, bypassed the output capacitors and use the balanced outputs as single ended to bypass the last op-amp.
There's a thread here with very useful information including the information that helped me complete my mods: http://www.diyaudio.com/forums/digital-line-level/142184-opening-new-dacmagic.html
