Cambridge Audio A5 Switch off squelch
Hi all,
Recently picked up a Cambridge Audio A5 amp from ebay to replace my A1 Mk3 se as I am having trouble finding replacement TDA1514A for that.
Anyway, the A5 seems to be a nice unit, however ive noticed that after 3/4s switching off the amplifier i get a kind of "squelch" noise.
I have traced it to the NE5532 Opamp in the Preamp stage (U105), i have desoldered the decoupling caps on that board and checked them (all ok) but did replace them with new good caps for the sake of it, but still get the noise.
Happens with or without a source connected and is attenuated by the volume control (so i know it is from U105). I have the attached scope capture from Pin 7 of the 5532, it is the same on pin 1 also.
Admittedly i can just make sure it is turned to zero before switching off, but wondered if this is a normal characteristic for the amp?
Edit: No idea why but my scope photo is upside down. will try to edit that.
Yes so similar in a way to my Quad 405 Power amp.
However this has the oscillation noise, which you could say sounds like a coat zip or a squelch, where the oscillation frequency varies as the power rail discharges.
But i wanted to see if other A5 users/owners had heard the same.
Squelch ? I have repaired communication receivers (tube ) in the past and had several with this control which regulates the carrier noise ( background ) in a no signal condition --it could be varied .
Do you mean--squeal ?--if so Audio Service is correct.
