Hi guys,
wasn't sure where to post this, I have an uncalibrated behringer ECM8000 microphone, from what I hear later models have been somewhat unreliable so I'm keen to have it calibrated, but don't really know where to start/where to lok to have this done.
Initial google searches have come up empty, does anyone have any suggestions?
thanks
thanks
Someone mentioned that some universities might be able to do it.
If someone has a calibrated mic and was willing to take the time, a comparison between your mic and theirs would result in some difference in frequency response which can be calculated, documented, and accounted for.
Chris
Chris
I have done some substitution calibrations - basically measure a flush-mounted tweeter on a fair-sized baffle with my microphone and others. A friend had a mitey mike that came with a cal file and I used that for a reference.
If you have a tweeter with a flat "specified" response you can flush mount it in a fairly large baffle and use the response above resonance as a calibration source of sorts by assuming that the mic should read flat and applying the necessary correction.
At low frequencies you can calibrate it yourself -
http://www.artalabs.hr/AppNotes/AP5_MikroMeasChamber-Rev03Eng.pdf
The Earthworks article referenced in the above paper.
"How Earthworks Measures Microphones"
'How to measure microphones and the implications relating to measuring loudspeakers'
http://www.earthworksaudio.com/wp-content/uploads/2012/07/how-earthworks-measures-mics.pdf
Earthworks Technical Articles
